imported_paradigm
ok...with the popularity and frequent questions regarding Duragloss products...how about making a FAQ thread that details each of the common products they offer? as a newb, i have found it confusing since the products are typically referred to by their numbers...and a definitive process on how to do a "full Duragloss treatment" can be intimidating.
i have questions about a few of the ancillary products (tire cleaner, glass cleaner, fabric cleaners), but will get things started.
Primary Protection Products:
Duragloss PBA - Polish Bonding Agent (601) - sealant bonding/curing agent. Duragloss' version of Zaino's zfx. apply this first, let haze, and DO NOT REMOVE prior to sealant step.
Duragloss TPP - Total Paint Protection (105) - polymer sealant. applied directly on top of 601.
Quick Detail / Maintenance Protection Products:
Duragloss AquaWax (951) - polymer sealant spray. spray on / wipe off. works on top of other sealants w/out binding issues (Zaino, 4* UPP, etc).
Misc Protection / Cleaning Products:
Duragloss #301 Vinyl and Convertible Top Dressing: The best product for vinyl convertible tops I have found in 5 years of Mazda Miata ownership. The product is easy to use, provides a nice matte finish and water beads like a fine wax after the product dries. Once dried, this product will not wash off onto windows or paint. ...SB_92_MX5
Duragloss Process:
1. Wash with DAWN or strip old wax/sealant from the paint with your product of choice.
2. Perform any necessary paint cleaning, polishing, and swirl removing (i.e. claybar, SMR, etc).
3. *optional step* Apply 601 PBA. DO NOT buff PBA off, as you will apply 105 TPP over PBA in the next step. PBA is similar to Zaino's Z1, not ZFX, if you are familiar with the Z system.
4. Apply the 105 TPP polish, using THIN coats. Do the whole car at a time, let haze, and buff off. If you used the 601 PBA in step 3, apply 105 TPP on top of the 601 PBA. Use the finger swipe test if you are unsure of when to buff the paint. Swipe your finger across a spot on the paint, and if it wipes away perfectly clean, with no smearing, it is ready for buffing.
5. Apply 951 AW on top to complete the protection steps. You can do multiple coats of AW for added “pop�.
6. *optional step* Use the 921 FC&S QD spray last, but the FC&S has little protective qualities like AW. The 921 FC&S will simply add more gloss and slickness.
7. Admire the great shine and enjoy fantastic protection!
Please Note:
Steps 1 and 2 are not Duragloss specific, and should be done regardless of the LSP that you use. Also, step 3 is optional (601 PBA), but it will likely enhance the durability and protection of the 105 TPP polish.
Maintain with the 901 CWC (Car Wash Concentrate). Apply 951 AW and/or 921 FC&S after each wash. …paraphrased from TigerMike
Duragloss Process:
Please Note:
