imported_DetailDan
I ordered my Nano Skin towel from Dave @ Innovative Detailing Solutions. Arrived in no time, cant wait to use it.
WCD said:We sell a kit with towels and ship to Canada all the time. There are about 3 places from which to order that I know about. Dave is one and ADS is the other.
Rob
hotrod66paul said:Got to use my nanoskin towel Sunday for the first time. Why did it take so long for someone to come up with this gem ? j/k. It was sooo... much easier to do my truck (F-250 4x4 crew cab) with the acres of surface. The marring was very slight and this was followed up by a full correction and application of opti-coat. This towel now has a spot on my detailing shelf no doubt. Have to also give credit to Tom Weed for driving up from Bloomington to Indianapolis and walking me through the opti-coat install. This guy ought to be teaching a detailing class. Thanks again for everything Tom.
DDN79 said:Did I miss it somewhere, but how do we clean these towels? I just ordered the kit today, so I might be out of the loop since I do not have the instructions in front me.
TIA
G
C. Charles Hahn said:Interesting stuff, David.... do you know if there are any plans to come up with a less aggressive towel as well?
I got an email from the president of SM Arnold (who also market the SSPT) after I made and posted my video review and suggested the idea to him in response, but I don't know who actually makes these products or what kind of influence they have over the manufacturers. It would certainly be helpful on some finishes, since I have found on particularly soft paint that it acts similarly to wet sanding with 4000 grit. Not usually a big deal if I'm polishing afterward anyway, but being able to lessen that effect would appeal to me.
Innovative Detailing said:Charlie,
Sorry I didnt answer sooner, had a busy day doing product testing and evaluating. Yes as you mentioned a less aggressive more consumer friendly towel is in the works....
For cleaning I just simply liberally spray my Nanoskin Glide lubricant on the towel and wipe dry with a MF towel.
The important thing to keep in mind with the SSPT and the Autoscrub pad is knowing the product and how it reacts to different temperatures. Like clay, these products do not react well when cold and hard...take for example a cold, rock hard clay bar against a cold panel on a vehicle....what you get is marring for sure. Same goes with this polymer material, it acts like clay....if you put it in the freezer and get it stiff, rub it on a cold painted panel and you will get marring.
Both clay and this polymer material act similar when very hot or when used on hot panels....it will stick and the performance is horrible. Once you get past the initial curve of getting use to the product, and how to best use it, it rocks!
As I have said before Nanoskin developed this polymer product to be used with their proprietary liquids....No other lubricant or Polymer sealant works as well as Glide and Shock....if you have purchased one of my promo kits, I am sure you will agree that the towel and "Shock" is just a ridiculously awesome product that delivers!
Today I worked with the Nanoskin Fine Grade Autoscrub pad which I am currently testing for the mfg using their new twin engine, twin tank, 45db extremely quiet Evergreen powerplant...using a pnuematic d/a and the Autoscrub pad makes it so easy for vehicle prep!
