MongooseGA
Dan,
The pad(s) I had the problem with was the 6.5" LC VC Orange cutting pad. I bought it from Autopia along with the 3 other white polishing pads.
I thought about the backing plate issue. I have the 5" flexible backing plate that came in my pad kit from Sonus. It's a pretty perfect fit for the velcro on the LC pad.
Patrick,
You are right. These pads go through alot, and are not indestructable. If I had used these pads say, 10 times, I would expect this to happen. What I'm displeased about is that I only worked 2 panels (The one small fender on my jeep, the hood on my mom's Sebring) and they are both falling apart. I would consider myself skilled (if not just comfortable) when using the PC, and I didn't put these pads through anything that my Sonus pads didn't go through.
If I did something to the pad that is not reccomended by LC (like the wash I used, backing plate, blah blah) then I'll drop it and learn from it. I just wanna know if it was a defect in the pad, and if it was, what can be done to fix the problem
BTW, let me know when you get those cutting pads in. I'll try to get a few of those and some new towels as well :wavey
Patrick,
