imported_rydawg1
tenorplayer23 said:Appreciate the feedback, but want to make sure I'm clear. Your feedback is somewhat counter to what Collonite says (although, that's the reason I asked these questions in the first place.....to get real world experience factored in to my product selection choice).
Per the mfr. description, 476 should be the most durable, all things being equal. 915 should be close in terms of longevity & is supposed to be the best looking of the three. But, most of the feedback is that they are roughly the same in difficulty to apply (and I suppose, remove).
845 (the liquid wax) is said to be somewhat less durable, a "finish" somewhere in between the other too, but by far the easiest to use.
It sounds like you have experience with all three products. So, in you opinion, is 476 easier to apply/buff, etc. than the 845? Just sounds like it would be, given the last sentence of your reply (since 476 is supposed to be by far the most difficult to use).
Just checking on the Collinte numbers you're referring to clearly understand your experience.
Thx.
See ya. :wavey
915 lasts longer than 476 or I got 3 bad tins of 476.:think:
I have not played with 845 enough to give my honest opinions on it.
Just make sure you apply it thin and if needed spritz a small spot of distilled water on a panel and spread the wax applicator into the water spreading out the wax evenly and thin. :bigups
