imported_OneQuickGT1
Member
Anyone tried this? I seem to remember someone trying it. Those that have, results? Any cure time between ZAIO and 1000p?
thanks
thanks
There was an article years ago call the perfect shine it talked about the whole sealant under wax debate. It pointed out that most waxes have heavy solvents that effected the sealants durability. The only wax that was recommended over a sealant was p21 because it did not have the harsh petro solvents. So the folks doing powerlock then 845 would probably get better results using power lock then p21 over the top. Soft 99 makes a solvent free wax called hydro wax it was created for the same reason. Soft 99 actually went as far as stating the solvents in most waxes are harsh enough to even effect ceramic coatings so they hydro wax specifically to top ceramic coating that a paste wax but uses water as carrier. If its still out there "the perfect shine" was a great read
I`ve done that combo quite a few times, works well, no issues.
William_Wallace said:There was an article years ago call the perfect shine it talked about the whole sealant under wax debate. It pointed out that most waxes have heavy solvents that effected the sealants durability.
I don`t really think AIO has much of any correction ability but does have some cleaning ability.
