What more aggresive, SSR2 or Menzerna IP?
prgallo
I have some heavy duty work ahead this weekend, most likely needing a cutting pad with a PC. I was thinking of doing:
IP w/cutting pad
SSR2 w/polishing pad
SSR1 w/polishing pad
Is this a bit redundant or could I use an abbreviated routine like:
SSR2 w/cutting
SSR1 w/polishing
and achieve the same results. I understand the cutting pad may take more than one pass on the horizontal surfaces.
Thanks
I used SSR2.5 with a polishing pad last weekend and it worked great. I followed up with SSR1 with a polishing pad in certain areas and then topped with EX, then Natty's 24hrs. later. SSR2.5 is very easy to use.
Ive used both and personally I think IP is more agressive than SSR2. I would say IP is about the same as SSR2.5. Its difficult to compare them, however, because SSR contains deminishing abrasives and Menzerna does not.
