wizardofahs
So i took my car in a few days ago, did the dawn, SMR, PPCL and zaino, looks good, but... i've knoticed waterish looking spots just below my windows. The last time i detailed the civic i didn't see them.. pretty sure they weren't there. At that point i did a few coats of souveren, that was only a little while ago. When i washed it this time i was also doing a friends civic, so the water set on mine for a bit before we were able to dry it (while we washed his). I saw the spots then and just washed over them with the mit and dawn again, then hosed off.
When i pulled it in and got my lights i saw they were still there. I used some SMR with the PC and went over the spots a lot... thought they were gone. But now with the zaino i can see them very well. I thought water spots took a week to develop into a problem... i read in the eBook that white vinigar does the trick... but wouldn't the SMR of taken care of them all? That's pretty tough stuff.. and it didn't put a dent in them. or do you have to vinigar before you SMR just to be sure and remove it all or something. Has anyone else had 'waterspots' that didn't use vinigar that SMR got rid of? looking close at them i think they might be something wierd with the cleacoat. I'll get some pics when i can. Untill then i guess i'm going to try the vinigar (over my 5 coats of Z....)
Looks like i'll probably end up striping the Z with dawn, using vinigar on the spots, then maybe SMR if needed to clean residue from the spots, and PPCL (is pinicle as good as P21s?)
