blonzz said:
...Should I clay the Viper before wax application? The tech I spoke with at Pinnacle said it was not necessary because the car was so new....
I'm with
sQuashed and
NickcZ28. You don't know what it went through before you got it. You should at least check the surface to see if it needs claying. I'd probably just do it regardless myself.
blonzz said:
T...Pinnacle advertises their Signature Series wax is optimized for metallic paint. Which will give better results?...
That's a personal taste thing. You'll never really know unless you try it for yourself.
blonzz said:
Back to the detailing. Should I put down a polish below the Souveran?...
Depends on what you mean by polish. I have a whole rant on the subject but I'll spare you having to listen to it.
Different polishes have different characteristics. Glazes, or "pure polishes" are mostly conditioners, meant to improve visual impact. Cleaner/polishes will also have cleaning agents for removing contaminants from the surface and may additionally have abrasives for smoothing out surface defects like swirls and etching.
Whether to polish before waxing depends on the condition of the surface, the paint itself and your personal tastes.
If the surface is pristine then it's up to you whether to polish or not. If you find that a glaze improves the look then by all means do it. If you find that your paint doesnt respond to glazes skip it.
If the surface has any defect like swirls, etching or staining then you'll need to polish to get it back to pristine condition.
Note: Pinnacle say that "Cleansing Lotion works without the use of abrasives..." so if you want to remove defects you'll need pick of something more aggressive like one of their swirl removers or Meguiar's ScratchX.
Also note: You apply a wax or glaze, you
work cleaner/polish. With waxing and glazing you're adding something on top of the surface. When polishing you're actually removing material from the surface so you need to work it to achieve the necessary cutting action.
PC.
