imported_Grouse
Review of touch up 123 paint chip repair. With a lot of pics.
The deluxe kit
2 oz. ColorFill (your color)
4 oz. Final Touch Compound
2 ColorFill applicator towels
1 Diaper Cloth Removal Towel
1 Microfiber Polish Towel
1 pair vinyl gloves
1 Professional Comfort Chip touch up brush
1 Professional Comfort Scratch touch up brush
2 touch up cups
Easy to follow instructions
http://www.touchup123.com/
1) Read the directions and give the bottles a very vigorous shaking.
The color fill will spate back into its base colors pretty rapidly. I made it a habit to shake it for a few seconds before every use.
2) Use the prep agent to clean old layers of wax off around the paint chips. If you do not do this the paint will not stick into the chips. I actually did a moderate wipe down of the major areas
3) Now mark all the paint chip areas. I did this by placing bits of blue painters tape 1 cm from chips that were through the clear and into the paint, and or 3 or more chips. My primary reason for doing this is so I would not loose track of the chips as I worked on the area’s. when you stare at the paint for so long you tend to get tunnel vision.
4) Start to work the color fill in using 1 drop on a bit of the lint less towel. I found it useful to shake the color fill for about 2 minutes before hand. Then shake it for about 5 seconds before each use. The key here is to build up thin layers till you get to about 80% of the original height of the paint. I went over the chips about 10 or more times for some of the deeper chips.
Here is an example of a chip as the layers are built up. This one was particularly tough.
As I finished with a chip or set of chips I removed the blue tape. Allowing me to focus on those remaining chips with tape.
The deluxe kit
1 pair vinyl gloves
2 touch up cups
