imported_pdsterns
I worked a couple of light scratches on my roof with Scratch X for about 10 minutes and applied it 4 times and sure enough it improved them quite a bit but they were still visible. Then I took out the pc and put a little Megs 80 on a green sonus pad. In about 2 minutes of working it I stopped and wiped clean. All gone. I know you're supposed to use the least aggressive stuff to improve problems but why knock yourself out when the pc will do it with such easy and Megs 80 is what a lot of guys start out with.
