BudgetPlan1
Well-known member
Uh Oh...although @ $225 a little rich for my blood. Polish Angel rep had this at recent Open House...smelled good if that counts for anything :lol:
PolishAngel High Gloss Paste Wax
For those who want the durability of modern chemistry, with the feel and experience of a high quality paste wax
PolishAngel High Gloss Paste Wax takes the chemistry of the sprayable PolishAngel High Gloss and molds it into an incredibly easy-to-use paste wax.
High Gloss Paste Wax was designed for those of you who want the feel and look and feel of a traditional carnauba wax, but with more durability and longevity than what typical carnauba paste waxes can offer. As with all PolishAngel products, you will not only get excellent results, but you will enjoy the process while applying it to your car.
Within the chemistry of High Gloss Paste Wax is 80% Titania and 10% Silica, producing an unbelievably glossy, reflective surface, that is incredibly durable at the same time. Because of this chemistry, High Gloss Paste Wax can be applied on top of existing layers of quartz/ceramic coatings without issue. With standard waxes, this is not possible, as carnauba-based waxes create a smeary, streaky finish on coatings. High Gloss Paste Wax works unbelievably well as a maintenance product for all coatings, giving you the hard protective layer of the coating, while retaining the ability to wax your car on a regular basis.
In between using High Gloss Paste Wax every 3-4 months, look to use PolishAngel High Gloss once per month after washing your vehicle for an extension of gloss and durability.
PolishAngel High Gloss Paste Wax comes in a decorative glass jar that will stand apart from everything else that sits in your detailing arsenal.
Directions
Use a soft, foam applicator to apply a very thin layer of High Gloss Paste Wax to the surface of your vehicle
Apply in straight lines with light pressure
Apply to all panels of the vehicle, then begin wiping off the wax where you initially started applying it
Use 2 high quality microfiber towels to remove all remaining residue, buffing off the wax residue in light, circular motions
