OakesDetail
I bring you a complete overhaul of this 2006 Evolution IX in Tarmac Black, the vehicle has been washed once in the last year and was in desperate need of a proper detail. The vehicle needed to be done in preparation for a photoshoot so my task was to make sure nothing went untouched, having an entire week at my disposal I went over everything and also documented as much as possible. Both fortunately and unfortunately this Evo was an excellent candidate for paint correction, so I was able to use this to my advantage as you will see in the pics below.
This particular vehicle, just dyno'd 609hp 519tq making it quite a machine, now it looks just as good as it's dyno sheet.
Process:
Full wash/degrease/clay
Menzerna Power Gloss - Orange (heavier areas)
Menzerna Intensive Polish - Orange
Menzerna 203 - Green
Menzerna Final Polish II - White
Optimum Opti - Seal
Pure Caranuba wax
Blood, sweat, tears, sweat and dedication
To start off, here are a few before photos of the car as it arrived, before the wash/degrease/clay of the vehicle
A quick snap of the clay bar
After the full degrease/wash/clay the vehicle was dried and then pulled outside in the remaining daylight to get an inspection of the paint condition. Once that was done, I pulled it back in to see how it looked under the spotlights...these photos show pretty well what I was up against.
Back inside:
After figuring out the best combination of pads/polishes, the correction got under way. As you saw with the before pics of the paint above, these photos show the difference between the corrected and uncorrected portions of the panels. Now onto the 50/50 shots!
Starting off with the passenger rear quarter panel:
Now for the trunk 50/50 photos
A brief half shot of the wing side blade
Here is a bigger scale 50/50, this shows the difference between the corrected rear as opposed to the uncorrected front door
Process:
Optimum Opti - Seal
Pure Caranuba wax
Back inside:
