Menzerna FP equivalent?
sbkang
What other product(s) would serve as an equivalent to Menzerna FP for ultimate surface gloss, not dependent on oils left on the surface? (I.e. as a prep for Zaino or similar LSP)
While I have not used FP II, I'm ready to throw up my hands in frustration with FP. It takes me more time to clean it off than to do the actual polishing. The IP works well; I can work it til dry then give it a quick swipe with the MF, but the FP is a different critter. I think the wiping issue doubles the time it takes me to work my way around the car.
1ZMP, GEPC, Sonus PC, are just a few that are comparable. I would choose the 1Z product myself, but that's just what I use. The only problem I see is that no matter which one you go with you are probably going to have to use AIO if you are going on top with a polymer sealant, isn't that what Zaino is? A sealant like SG?
Most people are saying that IP and FP work a lot easier with a rotary vs. a pc, and this is why you are having trouble. The FP probably isn't breaking down and the oils are just smearing all over the place on you.
