Menzera shelf life
elitemobile
Does anyone have an idea of the shelf life of some of the menzerna stuff esp. the final polish. I have a new GTO a guy wants polished and waxed so i figured id use some final polish i had laying around for 2 years...still good?
I have planning on throwing in a couple oz. of OP to cut down dusting
Thanks!
Oh yea im sure its fine. I guess the only way to find out is give it a shot and see what happens. Im sure its fine though.
Jim
you should easily get 3-5 years (or longer) on chemicals as long as they are stored in the right environment. i give my products a good shake about once a month...
I agree with giving everything a good shake every so often. That will help keep the product from solidifying as well as re-distributing the chemical properties of the polish/wax/sealant. Also, protect your products from freezing temperatures and you should experience a very long shelf life.
My FPII is about 2-3 years and seems to be working well. Just like everyone has already stated, shake the bottle thoroughly before using. I even shake every 15-20 minutes during use. My other Menzerna products seem fine IP, FG; however, my FMJ did change color to milky pink when it used to be an almost clear red. The FMJ doesn't have the foul odor yet which (accrding to CMA) seems to indicate that product is bad.
