Gyeon Wet Coat usage
DAC17
Member
I`ve been using this on a couple of my cars, but I think I may be using too much. I have less than half a .5L bottle left after two full-size cars. Can anyone advise, for instance, as to how many sprays per panel of paintwork?
Thanks.
Should be about the same as hydro blue. I do about 2-3 sprays per panel. Remember it spreads out once you hit it with the high pressure rinse. Another tip is fan spray it rather than spray in directly in one spot.
Good Info , I just ordered Wet Coat. Does it make a difference if you use a pressure washer or a regular garden hose with a good nozzle?
I`ve always used with hose as long as ya got some good water pressure, should be fine.
