foam pads
III
97 bonneville/98 Z71
I bought 4 meguiar's foam pads and I was wondering if after washing the pads with soap/water if I can re-use them with a different product. Here's what I mean: 2 of the pads I strictly used with a cleaner, then one pad with a polish/glaze, then another with a carnuba wax product. If I wash all the pads can I use the 2 pads that had the cleaner on them, or the polishing pad (the pads are kind of dark brown now instead of yellow) with a carnuba or polymer product, or should I just delegate them to my cleaner/polishing products only?
i try to keep them separate. no matter how clean you try to clean the pads, i think there's still some residue. it would be best if each pad was designated to types of products like you said. it would be a waste if there was a little polish left in a pad that you are trying to wax with.
A good cleaning with a little bit of mild soap (Dawn, etc.) in the sink with warm/hot water will remove any residue between the polishes, glazes, or waxes. I have used a dozen products on the same pad, after washing thouroughly of course, and have never had any adverse effects. There have been other threads about this if you search.
