BudgetPlan1
Well-known member
Hi Dave,
Got a chance to run this comparison yesterday. Tried to take pics but didn`t get any that showed anything worthwhile.
Flex 3401 w/ gray LC Force cutting pad, speed 5, 4 passes.
Rupes LHR15 Mk 2 with Kamikaze Beast backing plate, GG FCC, white Fast Correcting foam pad, speed 4.5, 6 passes.
In the end, results were 95% equal. The M101 was able to cut a bit deeper but that was on specific deep scratch that FCC couldn`t handle. FCC w the Flex couldn`t get to it either. Only M101 and some heavy pressure reduced it to livable...and it took some extra attention.
Remove that specific instance and results were pretty much equal; Flex combo a bit quicker, more force than style. FCC an easier and certainly less taxing task. Could also be due to my lack of technique with the Rupes.
Both finished out quite well, perhaps M101 a very, very slight disadvantage on hazing, both sections quickly brought to LSP ready with some quick passes with M205.
Glad I have FCC now, will be using it more going forward with various pads, looks like it`ll be quite good on perhaps a less aggressive pad on less beat up paint. Definitely gonna explore it more.
Slight edge to M101 in terms of cost and will still lean on this for the worst case scenarios despite the extra pounding from the Flex/gray combo. For me it`s the quickest, most mindless way to get past the compounding step in the worst of cases.
