Fk1 350
Wasatch
Anyone use this yet? If you have, what did you use it on? How was it applied? I really would like to know if it is sprayable and if it was diluted.
I have only used it on my tires. Used it from the sample squeeze/squirt bottle and put it on with a MF towel once then started using a foam pad. I really cant see how could spray 350. But I have never tried. Its pretty thick... like hand lotion thick. But I do like it... once I get it spread around and in the raised white letters(ARRRRGH) It seems to hold up well, even after rain, makes a nice matte black finish.
Thanks for the reply. I'm looking at using it on my tires as well. I guess if you diluted maybe say 50/50 with water it should spray on much easier, and that gallon will go a long way. Or I just might go the 108 way, but more expensive. When I put my order in for some other products, I will ask for a sample of 350 and check it out for myself.
