Dr. Beasley’s Nano-Resin Hydrophobic Coating - Anyone wanna try it?
BudgetPlan1
Well-known member
Picked it up last March, never opened, never used. Would like to see how it performs but I`m hoping that I`m done with this kinda stuff so if you have a vehicle to use it on (and report back) I`d be happy to send it to you N/C.
https://www.autopia-carcare.com/beasleys-nano-resin.html#.WhLs7YanG01
Nano-Resin is a semi-permanent ceramic paint coating designed to provide the longest lasting paint protection possible. It provides a durable, hydrophobic barrier which will last 2-3 years. Once your vehicle has been coated with Nano-Resin it will be protected from marring, staining, UV damage, and damage from airborne contaminants. And not only will it protect the paint surface, but it will give the vehicle a hyper reflective gloss beyond anything a wax or sealant could provide.
Many other coatings contain harsh chemicals which can be damaging to your health. You can tell just by smelling them. You`ll notice that Nano-Resin doesn`t have that same chemical smell that other paint coatings have. Dr. Beasley’s formulated a coating product without using harsh chemicals other ceramic coatings rely on, so you don`t have to worry about your health or the environmental impact of the product you`re using.
Technical Information: Nano Resin`s water contact angle is 110 degrees. One layer of this coating is approximately 2 microns thick. Nano Resin`s pH tolerance is 11.
Directions
Before applying Nano Resin, paint must be prepped. Clay and polish your paint with a light compound and a random orbital machine buffer. If your paint is heavily scratched, more polishing will be required.
Mix one part isopropyl alcohol (IPA) with four parts water in a spray bottle. Spray and wipe the entire vehicle with your IPA solution.
Wrap the suede cloth around the foam block applicator and apply ~10 drops of Nano on the cloth in a line.
Start by applying Nano in vertical lines down the panel. After you`ve covered your panel with vertical lines, go back and repeat with horizontal lines. This will ensure full coverage. Avoid getting the product in panel gaps.
When you see the product flashing (it will appear slightly iridescent), wipe the panel with a clean, dry, tagless microfiber towel.
Repeat steps 4-5 on each panel until your entire vehicle is protected. Reapply several drops of Nano on your applicator after a few panels.
After coating your entire vehicle, leave it undisturbed for one hour.
Additional Information:
Do NOT apply Nano-Resin in direct sunlight. Do not allow this product to freeze during storage.
If applied in temperatures less than 65-70⁰ the vehicle may need more flash time. In warmer, more arid climates Nano-Resin will need less flash time.
Inspect the vehicle in natural light for a better view of high spots.
Keep vehicle completely dry between applications and for at least 1 hour after final application. After 1 hour the vehicle can be exposed to light rain without affecting the bonding process.
Full cure will take 24-48 hours. After fully cured the surface will be noticeably glossier and the coating will be at full hardness.
Leaving the vehicle in the sun or under infrared lamps after application will shorten the amount of time needed for Nano-Resin to bond to the paint surface.
Avoid washing the vehicle with soap for 7 days after application. After this follow our prescribed maintenance regimen.
Keep bottle closed when not in use.
As soon as I have a free day I’ll be putting it on my g6 as I’ve got a bottle of it sitting
Very cool to offer this. mMy hat`s off to you.!
Thanks...i`m hopefully done with this stuff for awhile, wouldn`t get to using it until next Spring so may as well get used somewhere else. And even then may never have got used.
And, i am curious how it works and I`m just too lazy to do it myself.
