Cheap but is it worth buying for wheel detailing?
Dart Dual-Action Detailer and Scrubber with 7 Attachments
Item Number: 610-003
Comes with a manufacturer's 2-year warranty
Give your car the royal treatment with the Dart dual-action detailer and scrubber!
Your car will sparkle and shine after the Dart auto detailer set gets done with it. With seven different attachments, this set makes it easy to clean every inch of your car. The quick-release keyless socket lets you change accessories quickly and easily. The Dart Tool's dual-action switch allows you to change from reciprocating to rotary action in seconds. That's important because the more directions the cleaning device moves, the better the overall cleaning job. The high-torque gearing is up to seven times faster than standard rotary tools. The ergonomic design and contoured grips on the tools give you comfortable and efficient control. The accessories include:
Cone felt buffer - for rotary and reciprocating action to clean and polish contours, crevices, edging and intricate surfaces
Lamb's wool buffer and polisher - rotary action only, clean and polish smooth surfaces
Soft nylon brush - rotary action only, clean and remove grime, dirt and wax build-up from any hard to reach areas
Round soft bristle brush - for rotary or reciprocating action, clean and remove dirt and grime from trim, molding and any hard to reach areas
Straight soft bristle brush - for reciprocating action only, clean and remove road grime and dirt from around windows, head and tail lights, emblems and grout
2 Inch Rotary Sander - shapes and smoothes wood items. Perfect for when your other sanders are too large or too small
9 sanding disks - 3 coarse, 3 fine and 3 medium
Brass scrub brush - for reciprocating action only, abrasive scrubbing action for dirt and mild oxidation on metal (Note: will scratch paint and chrome surfaces)
Wheel-shaped soft bristle brush - for rotary action only - cleans and removes dirt and wax buildup
Other details include:
Handle measures approx. 12"L (curved for easy handling)
6' two-wire power cord, 120 Volts - for extended reach
All packaged in a PVC carrying case
Owner's manual and list of accessories included
