CCD $6.99 @ Big Lots
velobard
Active member
Found the California Car Duster at Bog Lots for $6.99. I know their inventory varies a lot from place to place. This was in Springfield, MO. Might be worth a look at your local store.
Grabbed one a month or two back. Works great as a pre-clean to QDing dusty paint.
The drawback is this is the plastic handle version that doesn't come with an actual case, just the display package that has buttons on the outer edge to snap back together.
The main thing is to let it sit on some newspaper once you get it so that the excess paraffin wax will soak up and not streak on your paint.
Well if it makes you feel any better, the one at Big Lots has a cheaper handle, lol. It's just a cheapo molded plastic thing that makes the CCD at Walmart look nice. But it does have the same CCD brush and I probably would've bought this one if I'd found this deal first. And like the other posted pointed out, it doesn't come with the proper case. I usually keep mine in the trunk so the vinyl case is a big plus.
