cant get swirls out..need help
andrew300
hey i just got my pc and got some ges 9,80 and 82. i was doing my friends black 03 nissan sentra specv and it has normal 1 year old swirl marks a black car usually has and they are everywhere. i tryed number 80 on it and worked it in good and went over it alot and they were all still there. what could i be doing wrong? could it be the foam pad that came with the pc that i am using? am i not working it in long enough? please give me some tips for removing these. id be using my sonus pads but my backing plate broke. would it really make a difference between the pc pad and the sonus pad? also how many times should i go over it with the pc? they are not deep so i know 80 can take them out its just trying to figure out what i am doing wrong.
I have never even used the pad that came with my PC. They call it a polishing pad, but I don't think it works very well for polishing.
I think it's probably the pad. I know #80 is a reputable product, so I don't think that's the problem.
Order a new backing plate and tell your friend to come back in a few days when you can use your Sonus pads.
The pad that comes with the PC is not very good. You should get better results with your Sonus pads. Also #80 really is not that abrasive. You might find that even with the Sonus Pad #80 can't get every thing out.
I agree, you should wait until you get a new backing plate so you can use your Sonus pads. And as stevet said, #80 isn't all that abrasive, you may want to have some #83 on hand just in case.
i have 83 but would that be to abrasive for paint thats only little over a year old? will it really cut through the clear coat fast? how many applications of dacp would it take to get through the clear? its not my car and i really dont want to mess it up but i might give it a try.
also what speed should i use on the pc 5 or 6? and should i put any presure on the pc or should i let it work under its own weight? i should work it until it turns into dust right and then buff it off?
Well, to remove the marring you have to remove paint, just the way it works. Doesn't matter how new/old the vehicle is, you just cut off clear until the marring is removed/improved. Know when to say "good enough"...but most people give up *long* before they take off too much clear with a PC and DACP.
Generally, people use DACP many times without problems. Just use common sense and you should be fine. Working by PC, as opposed to a rotary, is a very mild process. As you found out when the #80 didn't take out the marring.
I do almost all my polishing on "6" and I'll put some weight on the PC upon occasion. Try to let the *product* do the work, but sometimes you have to lean on it a little. Work the DACP until it turns to powder (don't apply too much) and be prepared to follow up with a milder product if it leaves micromarring.
I'd use the pad on 5 and work a small area (2' X 2'). Work it till you see the dust and a slight haze. Buff with an mf to check your work. I don't use any real pressure on the horizontal surfaces and slight pressure on the vertical.
Holler if you need help. That's what Autopia is for!
I say work the product in on 4,crank it up and lean on that PC a little.. Sometimes pressure is required.
