Best Spray Detailer?? Opinions
blownvert
I was going to go ahead and get the zaino SD or grand finale because I have always got there line of polishes but not SD. What is everyone using on a black car? I want it really deep wet and black gloss.
I have a black 05 mustang gt and i use PB EX topped with Natty's blue it really shines and has that wet look :cool:
I did a little test last week on one side of my truck (I reported it here in another thread). I did the front door panel, the back door panel, and the fender panel using 425, Menzerna's HGAS and a home brew of Klasse SG with distilled water in a mister spray, one product on each panel. I stood back and could hardly tell a difference among them. However, if push came to shove I would have to say the Menzerna had a tad more gleem to it. It should be noted that my truck is silver and I do not know if this same effect would be seen on black - but I assume it would.
Sonus Detail spritz is brilliant as is 1Z raindance, HGAS, Werkstatt and UGE
FK1 425 sample is on the way to me from mad ix in melbourne
I'll join the FK1 #425 masses. I've never used anything as good and I've gallons of other products in the garage. Obviously no one can try them all but I've been through a dozen + and 425 whups 'em all.
My first question is this a QD or a spray wax. I think QD gets thrown around too much. The second is how does this stack up to Menzerna HGAS that I have that along with Megs 34, and megs quich detailer, and EF clear pearl.
If you are using the Zaino polishes already then I would be wont to tell you Zaino Z8 would be your best choice.
I'm also an fk 425 fan. Not only does it work exceptionally well, but it smells like bubble gum! :xyxthumbs
If not that, then I'd use either Clearkote Quickshine or Jeff's Werkstatt Quick Wash. But I could understand, since you're using Zaino, to go with the Z-8 since it's specifically designed to complement that system.
