Shady...I would try a spot first..like the trunk lid..if it goes well then I say it will be ok....reason I say this is some sealants take a while to really set up and you may just push it around with using AW....I have used AW after doing DG 105 a hour later and worked out good..it was a test....then I tried AW over UPP after a hour..it was pushing UPP around...so like I said..try a spot first....and if it goes good then go for it..if it starts to smear ..stop....
Also,,remember..1 spray per panel...do not over soak a panel..a little goes a long ways..I use 2 MF's one to apply and one to wipe...
Do a sweep motion when spraying to get it spread out....wipe in and wipe off...after a few panels the application MF will be primed up and will go better...
AL
