I haven't used them in extreme heat/humidity conditions, but I did use both under these conditions: outside temp in the high 70s, vehicle (black metallic paint) pulled into direct sun for extensive inspection, which heated it up, followed by sunlight coming in through window during subsequent touch-up correction which also heated the panels up more than I liked (but let me see what I was correcting). The only problem seemed to be earlier flashing. This could probably be mitigated with the addition of a high-lube polish or some kind of pad treatment/QD but I didn't bother trying it as I didn't have a big enough problem to feel I had to do something about it.
Strictly a guess: I wouldn't *expect* humidity to be a big issue but it might make for a slightly oily residue effect when wiping off; nothing some kind of cleaning/QD product wouldn't solve IMO, but again I'm just speculating.
Oh, and as best I can tell a *huge* part of why these need to be worked at low speeds is the nature of the abrasives- they simply correct, break down, and otherwise behave better when worked at low speeds.
Once they break down you can crank things up to get a nicer finish (with the now-broken-down abrasives), but at the risk of tougher wipe-off (use a QD). *I* don't crank it up much myself.
